Usata pochissimo solo per prove in labo. Manuale allegato, Valore sui 450€,
Vendo 230,00€
AC A(50/60Hz) 200mA/2/20/200A/1000A|±1.5%rdg±2dgt (200mA/2/20A)|±2%rdg±2dgt (200A 0~500A)|±5.5%rdg (501~1000A)
AC A(WIDE) 200mA/2/20/200/1000A|±1%rdg±2dgt [50/60Hz],|±3%rdg±2dgt [40Hz~1kHz] (200mA/2/20A)|±1.5%rdg±2dgt [50/60Hz],|±3.5%rdg±2dgt [40Hz~1kHz] (200A/0~500A)|±5%rdg [50/60Hz],|±10%rdg [40Hz~1kHz] (501~1000A)
Conductor Size Ø68mm max.
Effect of ExternalStray Magnetic FieldØ15mm 100A 10mA AC max.
Frequency Response 40Hz~1kHz
Output Waveform : AC200mV against the maximum value of each range (1000A range is 100mV)
Recorder : DC200mV against the maximum value of each range (1000A range is 100mV)
Withstand Voltage 3700V AC for 1 minute
Applicable Standard IEC 61010-1 CAT.III 300VIEC 61010-2-032
Power Source 6F22 (9V) × 1 *Continuous measuring time: Approx. 60 hours
Dimensions 250(L) × 130(W) × 50(D)mm
Weight 570g approx.
Accessories 9094 (Carrying Case)6F22 × 1Instruction Manual
